whats up guys do you think it is imperative that i check the valve clearance on this setup? comp cams 292 adv dur cam .501/.501 lift, 64 cc chamber heads, 10:1 flat tops with two valve reliefs and .025 deck height?
I don't know what pistons you are running, but I don't think there are too many flat top pistons out there that you would have to worry about clearances with only .500" lift. You could clay the pistons to be safe.
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
