-   -   valve clearances sbf (http://www.hotrodders.com/forum/valve-clearances-sbf-143154.html)
maniacmikes 08-07-2008 05:24 AM
I just ordered a set of procomp 210 cc heads with 2.050 int. & 1.60 ex. for my 393 stroker. I will be checking piston to valve clearance .
Has anyone running these valves had any problems out of the ordinary =ie valves hitting the block etc.?
.545 lift hyd roller @ 244
. 100 dome kieth black pistons
1.72 : 1 scorpion roller rockers
:confused:
scottford351 08-07-2008 09:09 PM
Biggest fitment issues with them are port alignment (raised port)and valve cover sealing (rails are narrow). Some have push rod rubbing problems but the 1.72 rockers should take care of that.
maniacmikes 08-10-2008 05:39 PM
210 cc procomp
Thanks
They should be here on Monday I will let you know how they fit !!!
scottford351 08-10-2008 07:02 PM
A 1262R Felpro intake gasket will help with port alignment. They are thicker than the 1262. Stay away from the rubber/steel core valve cover gaskets on those heads, they will leak like crazy. The cheapie cork gaskets can be formed and glued down to fit the shape of the rails.
You don't live too far from me, maybe 80-90miles :thumbup:
maniacmikes 08-12-2008 09:19 PM
351w in a 88 mustang gt I like to race in the ford show
Thanks for all your help !!
Are you going to the nmra show at National trails the end of the month ?? :cool:
scottford351 08-12-2008 10:06 PM
Probably not. I have spent over 2 grand on the new house I'm building in the last 2 days. Not much money left for hobbies. My butt needs to be working on it every spare minute if I'm going to move in by fall. :D
