Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - valve clearence
Thread: valve clearence
Old 10-07-2012, 07:50 PM
BOBCRMAN@aol.com's Avatar
BOBCRMAN@aol.com BOBCRMAN@aol.com is offline
The heads would have had to been milled .100" to get the valves even close to the pistons. Of course then nothing else would fit.
You probably have a three way timing set installed at the wrong position.
I just had a customer, two months ago, with similar problem.. Went thru 16 bent exh valves, eight broken studs and 12 pushrods. Not to mention the gasket sets.
I told him the first time what the problem was. But, customer is always right. Hard headed and stubburn too..
