Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - valve clearence
Thread: valve clearence
Old 10-07-2012, 07:57 PM
adantessr's Avatar
adantessr adantessr is offline
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
Originally Posted by crazechris85 View Post
So the exhuast valve is hitting what way would I go advance or retard cam timming and about how much would that do for the clearance I can only 6 degres. Eather way???
You want to advance the cam to get the exhaust valves to close sooner. If you want to know how much difference it is going to make, put a dial indicator on the valve end of a rocker, and turn the engine 12 degrees ATDC ( this would be 6 degrees on the cam ) and see how much that brings the rocker up
