Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - valve clearence
Thread: valve clearence
Old 10-07-2012, 07:57 PM
cdminter59 cdminter59 is offline
valve clearance
Sounds like the first thing you should do is have them heads CC'ed. What thickness head gasket are you using? Use a .041 head gasket and place some clay on top of the piston. Bolt the head on to check the Valve to piston clearance.
