Most SBC heads with large valves that I've seen have the intake valves about even with the deck.
Just a thought, are you certain the pistons are installed with the valve reliefs towards the intake manifold? ssmonty |
Heads are useless on earlier blocks. This area (Flint) was where they were originally produced and several hundred "escaped" from the factory. I have seen pipe threads tapped into the front of the heads bypassing into the intake manifold. Entire front welded up and then drilled for conventional cooling, etc. All in vain, as the heads overheat internally and won't work. |
so i got it fixed it turns out i slipped the timming gear on the wrong way
got everthing all back togahter adn running its a bit sluggish at low r's anything over 2500 it revs like a chainsaw i was woundring if anyone else is running bowtie heads maybe some pointers thanks
Did you install new lifters with the cam? Are you sure you are using the correct lifter for the cam (solid vs. hydraulic)? What about pushrod length? Did you install longer pushrods or did you check valve train geometry to get the correct pushrod lengths? I know these questions probably seem elementary but...................
| Piston clearence.. take a look | 1fast62 | Engine | 12 | 12-15-2011 06:12 PM |
| valve clearence | mainejohn | Engine | 5 | 01-17-2011 10:08 PM |
| wheel well clearence | burnt olds | Suspension - Brakes - Steering | 0 | 05-30-2010 03:07 PM |
| piston to valve clearence/quench question | babygene41042 | Engine | 9 | 07-23-2007 06:24 PM |
| Vortec Heads Valve Clearence | rpainter87 | Engine | 3 | 03-19-2002 03:59 PM |
