Which valve cover. - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-13-2013, 11:43 PM
Banned
Originally Posted by americanLT1 View Post
You guys shamed me into it, I removed the map sensor today and will mill a cover for it.
Auto Gear, The machine turning on the plate on the manifold was done with a kit from Eastwood. They come in 1/2" or 1" diameter and appear to be some sort of rubber impregnated with various compounds. I did mine with the 1/2" diameter roll and the most difficult part is maintaining the spacing for the overlap. I did mine in a milling machine so indexing was easy and accurate but still easy to screw up, ask me how I know I was getting the hang of it by the time I made the plate on the manifold because I made all the plates for my custom dash.
I wanted to carry the machine turning into the engine compartment so I continued the 1/2" circles and 3" circles on the stainless steel firewall.
The firewall I did with 3" scotchbrite pads. I laid out the circles a row at a time with a magic marker and used the mill like a drill press and just laid the scotcbrite pad in the circles. It took a bunch of pads though, stainless is tough.
Also, when doing the 1/2" circles on aluminum you have to get the speed right, to fast and it will burn the aluminum, to slow and it doesn't cut well. I forget what speed I ran it at but it was around 600 rpm.
I used a mix of water and wd40 for coolant and dabbed it on with a brush. I could only get around three or four circles before the rubber roll would need to be dressed because it seems to load up.
I would dress it with 220 grit adhesive backed sand paper stuck to a piece of flat stock that I could just lay on the mill table and bring the spindle down to touch the paper that way it would dress the rubber roll flat so you get a clean circle.
It is very time consuming, so patience is a virtue
like it, but not for me, I'm not good with virtues
  #17 (permalink)
Old 05-14-2013, 08:56 AM
im a shoprat. i LOVE the jewling. bring a little gunlove to the hotrodding world. definatly my style! i have a jewling kit for my mill but its for doing smaller peices like bolts and magazine followers but i could use that ideah. thank you for the insight!! wish i had the means to do the whole firewall!!! that is phenominal! here i am thinkin diamond plate. that is way better ideah with the jewling.
  #18 (permalink)
Old 05-14-2013, 09:20 AM
I am confused. lol
  #19 (permalink)
Old 05-14-2013, 12:55 PM
"jeweling" is gunsmith-speak for 'engine turning' Those swirly geometric patterns laid out on (usually) aluminum. Apparently there was a reason for it, besides looking very early 1900-1950's cool on airplanes, cars etc. It was also done to spruce up pocket watches handguns and rifles. Heres a link to pictures
My first attempt at 'Jeweling'
  #20 (permalink)
Old 05-14-2013, 03:22 PM
Confused??
Originally Posted by nthogdog View Post
I am confused. lol
I am not confused about the jeweling. The engine compartment was already a work of art. I just have a different view in what is not enough and too much. I try to live somewhere in the middle. Too much will hurt and too little has the same effect. Kinda like breathing air.
  #21 (permalink)
Old 05-14-2013, 07:12 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Just got a new Ruger Mark 3 (modded to remove the LCI and mag disconnect along w/a Volquartsen trigger and sear, Hogue grips not on it yet). I'd love to do the bolt on it...
Engine turning aids lubrication retention and can lessen friction. But LOOKS bad-A, too.
  #22 (permalink)
Old 05-14-2013, 07:23 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
For the valve/coil(?) covers, I like the flat fasteners- even though I do like acorn nuts (just not in this application). Otherwise they look real good to me.
  #23 (permalink)
Old 05-14-2013, 11:24 PM
techinspector1's Avatar
Wiki Edits: 326
My wife thought the valve covers on my lt1 look a bit plain and unfinished so I fabricated a trim plate to mount on top and machined some stainless washers to go under the chrome acorn nuts. I'm not sure I'm crazy about it.
What you guys think?
I think you should finish the whole thing off in flat black rattle can and tell the wife to go fix you some eggs.
  #24 (permalink)
Old 05-15-2013, 12:26 PM
Theres a couple guys over on the RimfireShooting.com Forum that turn out some beautiful Rugers and custom trigger jobs (although I have lusted after a VQ for awhile). Nice piece, price on em is SKY HIGH here
To the OP: This obviously aint your first rodeo, what else have you done besides the rambler
  #25 (permalink)
Old 05-15-2013, 11:48 PM
ruger mark series, love em or hate em. i love em. where im at cobalt, your a crook. better take two rounds outa that mag before posting pics. that mark111 is deadly with more than 7 rds. on topic though, i bet you can integrate lots of ideahs back and forth. i used an old ratchet handle and some aluminum strips to make stabilizer struts for my mini-14's and cut out action shock buffers from an old hay conveyor belt. used an otis rifle cleaning cable for a choke cable on my old s-10. made a little bracket for it with some spring tension...worked mint.
The Following User Says Thank You to s-10again! For This Useful Post:
AutoGear (05-16-2013)
  #26 (permalink)
Old 05-16-2013, 01:40 AM
Pantaz's Avatar
... The machine turning on the plate on the manifold was done with a kit from Eastwood. They come in 1/2" or 1" diameter and appear to be some sort of rubber impregnated with various compounds. ...
You can get Cratex rubberized abrasives in sizes from 3/16" to 1" diameter (all are 6" long), and a variety of grits.
I think I used the "fine" grit for an aluminum panel, iirc. I also remember I had to experiment with how far to extend the abrasive out from the collet, so it couldn't wander too much.
  #27 (permalink)
Old 05-16-2013, 06:17 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The complete VQs are expensive, regardless! I mean, about $950 for the Deluxe 'stripper' model (no grips, even) up to god-only-knows for the top shelf models? Yikes! I paid $319.00 for it plus $20 to my FFL holder and another ~$80 for the VQ trigger & sear, hammer bushing (BAM), and grips. Far cry from a full-zoot VQ but it'll shoot better than me, now that the trigger works.
There's a guy on eBay doing bolt jeweling, it would be about $40 (includes shipping both ways) to do mine. If I were to do it, I'd probably use him if he checked out.
Jeweling a flat surface is one thing but doing a curved surface w/a radius as small as a bolt would be more than I expect I could do using my drill press.
Sorry about the hijack, americanLT1. I would like to say the workmanship looks top flight on your American. Those trunk hinges- are you ****ting me?? If the rest is as detailed, that's a show car, me amigo!
  #28 (permalink)
Old 05-16-2013, 09:18 AM
More eggs
Touche! Could not have said it better.
  #29 (permalink)
Old 05-16-2013, 09:34 AM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Hail yeah now that's what i'm talking about Richard.
Cole
  #30 (permalink)
496CHEVY3100's Avatar
Built Not Bought
Last journal entry: 53 ad3100
Al the people who are condemning the rambler,mabe you should post a picture of YOUR cars to show ,what it should look like,??.
Breather/PVC valve in valve cover juiced66malibu Engine 3 08-02-2010 07:28 AM
Suggestions on valve cover pcv valve baffle please! 67 Deuce 4 Me Engine 4 04-04-2005 05:45 PM
valve cover Gr8 '48 bow tie Engine 3 08-29-2004 11:33 PM
PCV Valve - SBC - 50's style valve cover spudone Engine 4 10-03-2003 08:22 PM
M/T Valve Cover ffcagle34 Engine 4 10-30-2002 08:39 AM
