Valve Cover Adapters - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-09-2004, 06:54 PM
NAIRB's Avatar
Does anyone know of any adapters available so I can use my early, staggered bolt Corvette valve covers on the later style, straight accross heads?
Old 02-10-2004, 04:20 AM
roys63's Avatar
Old 02-10-2004, 04:59 AM
302 Z28's Avatar
GM Performance Parts has them, but they ain't cheap.
Vince
Old 02-10-2004, 05:51 AM
POOR SEND HELP!!!
Vince
Aren't they in the range of $100-$160 depending were you get them?
Old 02-10-2004, 06:17 AM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Being the cheapa$$ that I am, I would spend a couple hours in the shop and build my own. All it would take is a piece of 1/4 inch plate, a package of jigsaw or sawzall blades and a hand full of machine screws.
You could just use a valve cover as a pattern to trace the shape onto the steel. Cut out the desired shape leaving room for the double holes. Drill and counter sink the 1/4 inch holes that will hold the newly made spacer to the head. Drill and tap the narrow holes for the old style covers for 1/4 inch cap screws. Use flat head machine screws to hold the spacer down and install the valve covers with 1/4 inch x 1/2 inch long cap screws. I think 1/2 inch would work with valve cover hold downs. Of course it will take two pairs of gaskets.
I have never seen any of the adapters, but I can not imagine them being much different that the above.
Edit: After some more thought, I think that you could permanently install the spacers with RTV silicon which would make them less noticable.
Later,
Chris
Old 02-10-2004, 06:58 AM
MI2600's Avatar
Member# 3287
I've only seen the centerbolt to old style adapters, and they're about $100 new. If you could find a cheaper set at a swap meet, you could probably adapt from them.
SPRING IS COMING! Pass it on.
