Valve cover bolt question. - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-13-2009, 09:33 PM
rajsid's Avatar
Putting new steel valve covers on my big block 502. It's hard to find chevy valve cover bolts locally. I went and picked up some grade-8 bolts from the local hardware store. It has the correct thread count.
Does the bolts for the valve covers have to be heat treated? Will the grader-8 bolts work?
How much should I torque down the valve covers. Im using steel valve covers with felpro rubber gasket.
Old 06-13-2009, 09:36 PM
OK, please double check, but I'll throw this out there.....
1. the screws should be 1/4-20
2. Grade 8 not a problem, not needed, just not a problem
3. Hand tight and one revolution of the screw should do it.
Old 06-13-2009, 09:54 PM
rajsid's Avatar
Thanks for responding..
I did get 1/4-29 size bolts.
Again, does it have to be heat treated bolts?
Old 06-13-2009, 09:58 PM
No. Grades reflect sheer strength. Plain old bolts are fine.
Valve Cover Question Camaro2 Engine 2 06-11-2009 02:40 PM
Valve Spring Compressor Tool Question leejoy Engine 9 02-27-2008 11:57 AM
center bolt valve covers jesse01 Engine 10 02-18-2005 07:50 PM
SBC Valve Cover Question Jag Daddy Engine 4 10-31-2003 05:03 PM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
