Valve Cover Conversion - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-13-2007, 10:45 PM
MI2600's Avatar
Member# 3287
Anyone used one of this converters/adapters for using the old style SBC perimeter valve covers on the newer center-bolt valve cover heads?
I checked out Summit and their set says you have to use "narrow" rocker arms..? I was going to use them on a set of Vortec heads, but their self-aligning rockers are anything but narrow.
I'd like to hear about their sealing and if they look goofy. There's no sense in using them if they stand out a mile and look phoney.
Old 09-14-2007, 07:01 AM
302 Z28's Avatar
I have a set of the GM Performance Parts adapters on my Fastburn, they work great and do not leak. I can't speak for Summit, but I can guess where they are made.
Vince
Old 09-14-2007, 07:18 AM
MI2600's Avatar
Member# 3287
thanks 302. I'll check them out.
Old 09-14-2007, 09:35 AM
302 Z28's Avatar
Look for them on Ebay, new they are $150.
Vince
Old 09-14-2007, 03:26 PM
MI2600's Avatar
Member# 3287
Vince,
Are you using self-aligning or standard rockers?
Old 09-14-2007, 05:04 PM
Vince
My Fastburn heads came with BOTH patterns ... the older 4 bolt around the gasket type and the 4 center bolt type ...
Old 09-15-2007, 08:42 AM
Vortech 4.3's Avatar
jack of all trades
i have vortec heads. i was thinking about milling holes and brazing/welding bungs in them for perameter valve covers. but i have yet to see perameter covers for my 4.3, that i like. and i watch ebay all the time.
Valve cover conversion foxman267 Engine 1 03-23-2007 07:38 PM
PCV and Valve cover baffles? 69ChevelleAddict Engine 4 07-30-2005 11:56 AM
Suggestions on valve cover pcv valve baffle please! 67 Deuce 4 Me Engine 4 04-04-2005 06:45 PM
Valve Cover Gasket Leak 18-FEVR Engine 9 01-01-2005 01:44 PM
Valve cover gasket replacement Migal12 Engine 10 09-01-2003 03:38 PM
