Valve cover repair - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-29-2005, 11:44 PM
Valve cover repair
I have a set of valve covers that are in good condition for the most part, but have some dints in them. Would it be OK to use filler on this even with the higher temp of a running engine?? Any thoughts or ideas about this would be helpful.
Thanks
John
Old 12-30-2005, 04:05 AM
No problem what so ever. These small dings could also be metal finished pretty easy so you don't need any filler. If here was ever a time to dabble in metal finishing, you have it. If you take your time and push up the metal to level you can get flawless surface.
If you want to try that, just ask. If you want to fill them, go for it, it will work just fine.
Old 01-02-2006, 08:12 PM
Thanks MARTINSR for the offer of teaching to metal finish, but right now i don't feel like i could make something decent in a limmited amount of time that i have. So I think that filler is the way to go.
Thanks
John
Cheap rust out repair cover zonk Body - Exterior 1 05-10-2005 04:50 PM
Suggestions on valve cover pcv valve baffle please! 67 Deuce 4 Me Engine 4 04-04-2005 05:45 PM
Valve Cover Gasket Leak 18-FEVR Engine 9 01-01-2005 12:44 PM
Valve cover baffle and breather question Jag Daddy Engine 4 03-19-2004 03:29 PM
over drilled valve cover bolt jrm123180 Engine 3 02-27-2004 07:14 PM
