As SS said they should fit fine, if you're really concerned you can always get the thicker Fel Pro cork v/c gaskets. Another easy way to measure the height of the roller tip is to rotate your assembly until you get 2 valves closed (roller tip all the way up) one near the front of the head and one near the rear. Then lay a straight edge across the tips and measure the height from the bottom of the straight edge to the v/c mating surface...with the gasket you'll be using.
| Valve Lash adjustment | hiball | Engine | 36 | 05-11-2009 10:12 AM |
| valve covers | fast79malibu | Engine | 16 | 01-04-2007 01:47 PM |
| Roller rockers under stock valve covers | curtis73 | Engine | 4 | 11-19-2006 06:53 PM |
| GM fast burn heads | batman09 | Engine | 1 | 10-26-2004 09:32 AM |
| Cam Help | black66 | Engine | 3 | 05-12-2003 06:15 PM |
