Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Valve Covers
Thread: Valve Covers
Old 10-08-2012, 02:55 PM
66GMC's Avatar
66GMC 66GMC is offline
Get in, sit down, hang on
Last journal entry: Cab Removal
Originally Posted by LBL View Post
Before I start pulling the engine, is there anything else I should consider other than blowby that might be creating too much crankcase pressure ?
Try doing a "wet" compression test first, and compare to the "dry" readings. That should give an indication as to how much is getting by the rings?
Definitely install the correct baffles, and inspect/replace the PCV valve (and filter, if equipped)
How about the "china wall" seal at the front of the intake?
Fords also use an o-ring to seal the distributor ... right?
Any oil leaks from the front of the engine will get blown all over the place by the fan.
