Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Valve Covers
Thread: Valve Covers
Old 10-12-2012, 08:49 PM
LBL's Avatar
LBL LBL is offline
Running Down the Road
Last journal entry: Interior
Test
I did a dry compression test and the cylinders are all between 145 and 160 with most being 150. The 'o' ring is good on the distributor and I put the proper baffles in the valve covers. To do the wet compression test, do I just put a squirt or 2 of oil in each cylinder just before doing the test again ?
