Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Valve Covers
Thread: Valve Covers
Old 10-14-2012, 04:20 PM
66GMC's Avatar
66GMC 66GMC is offline
Get in, sit down, hang on
Last journal entry: Cab Removal
IMO, 10 psi signifies fairly significant wear, and is probably enough leakage to create positive pressure in the crankcase.
The baffles will likely help a lot. Like SSMonty said, check the PCV valve and make sure that the entire PCV system is set up correctly.
You need filtered air going in on one side of the engine and a PCV valve connected to manifold vacuum (quite often from a carb spacer plate on a Ford)
