Valve Covers - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-01-2010, 10:08 PM
Valve Covers
Opinions on this set of Edelbrock valve covers (http://www.summitracing.com/parts/EDL-4495/)?
I'm looking for a decent looking cover that isn't insanely expensive. They seem to be a little on the cheap side. Am I getting a deal with these, or are they cheap for a reason?
Old 10-02-2010, 12:54 AM
327NUT's Avatar
Well yes they are cheap because they are most likely Chinese made and just chrome. You can find the same thing on ebay (might not say Edelbrock)....ok, I just looked on ebay, punch in "mopar valve covers" and you will find 683 matches. Every kind of v/c you could dream of...and a lot cheaper....good luck
Old 10-02-2010, 01:59 AM
ericnova72's Avatar
More for Less Racer
Look for cast aluminum or fabricated aluminum if you can afford it, much sturdier than chrome plated steel, lot less chance for having a leak.
Old 10-02-2010, 07:41 AM
Aluminum covers have more rigid flanges and with a good rubber gasket they will seal well. Chromed or painted steel covers with perimeter bolts have more flexible flanges, and when overtightened they bend and become harder to get a good seal.
Some of the newer engines use center bolt covers, so you have more even pressure pushing down in the middle and sealing the perimeter of the cover to the head. I don't know if that style of cover is available as a retrofit for Mopar engines.
Bruce
Old 10-02-2010, 11:29 AM
Thanks for your help guys. The aluminum ones seem to be a little out of my price range though. I'll be sure to not overtighten the bolts.
Old 10-02-2010, 01:37 PM
Last journal entry: Paint
Don't know where the Edelbrocks come from. You can buy the Chinese chrome valve covers at the big swap meets for as cheap as $10.00 a set.
Builder says 1/4 more on rockers....HHHMMM? sooper Engine 29 07-16-2010 01:17 PM
David Vizard's Idea of Almost Bottoming Hyd. ? BUFFALOBILLPATRICK Engine 46 06-24-2010 02:25 PM
383 engine tapping and oil burning- weird RowShan Engine 15 10-10-2009 05:07 PM
Valve Lash adjustment hiball Engine 36 05-11-2009 10:12 AM
Valve covers. mrdreex Engine 17 11-13-2008 12:52 AM
