Valve Covers - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-06-2003, 01:15 PM
Post Valve Covers
I have a set of the Edelbrock Aluminum valve covers and they are stained a little and have a little bit of oil on them. Do yall know what i could use to shine these back up and clean them real good, i have tryed soap and water.... Mothers polish and the mothers dosent work very well i was wondering if there was anything else that i could spray on there or rub on and wipr or rinse off. Thanks
Old 02-06-2003, 02:02 PM
Post
if theyre just aluminum and not coated or anything use some laquer thinner to take off the grime,then polish it up with that mothers stuff,good luck and have fun.
Old 02-06-2003, 02:03 PM
kiaserknife's Avatar
Post
elbow grease works for me
Old 02-06-2003, 02:13 PM
Post
yeah they are just aluminum.... no coating what does the thinner do? clean all the trash off of it? then the mothers will shine it up?
Old 02-06-2003, 02:22 PM
E.T. divided by $ spent= Speed
Post
Try oven cleaner on an inconspicuous spot.We were gonna clean an aluminum intake with it so,we tried it on an old cast aluminium starter head and it came out like new.But try it first,ya never know,I've only tried it once so I give no warrantie.
Old 02-06-2003, 05:16 PM
bluesman123's Avatar
Post
oVEN CLEANER (WHICH IS BASICALLY THE SAME AS ENGINE CLEANER) SHOULD BE SAFE .... damn caps key ... where was I ... oh yeah ... it should be safe because it is a strong base (alkaline). Aluminum doesn't react much with a base. But watch out for acidic cleaners like some drain cleaners. Those will wreck your covers in a heartbeat. Like the man said ... try it in a hidden spot first.
Old 02-06-2003, 05:33 PM
Post
Might try mag wheel cleaner there are a couple of different kinds out there.But like anything else you try best test it on a hidden spot to see if you like the results.If all else fails you might check out bead blasting it is not costly and leaves a nice finish.
[ February 06, 2003: Message edited by: oldred ]</p>
Old 02-06-2003, 05:37 PM
5.0Towncar's Avatar
Post
DON'T EVER USE CASTROL SUPER CLEAN(PURPLE STUFF), I got some on my cold air intake tube that is pollished alluminum and it oxidized it. Had to polish the hell out of it with "Mothers Mag and Alluminum Polish" (Little red can). Steve
Old 02-06-2003, 07:05 PM
Post
oh yeah i did forget to mention that it is polished aluminum sorry about that, can i still use oven cleaner? or will it oxidize it, i think that mag wheel cleaner may work pretty good but im not too sure never polished valve covers before, but i polish my wheels with mothers. but these vavle covers are kicking my butt with the mothers.
Old 02-06-2003, 07:11 PM
5.0Towncar's Avatar
Post
I don't know about rim cleaner,oven cleaner might be to harsh, andAs long as the mothers is turning blackish with color then your taking off dull aluminum. Remember the key is to wipe it off before it looks like crude oil. Make sure that you use a clean cloth to wipe it off. Steve
Old 02-06-2003, 08:04 PM
Post
alright, thanks alot for the replies on this. im going to try it out tomorrow, its all nasty outside tonight raining and windy and cold.
Old 02-07-2003, 06:15 PM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
Post
On polishing the valve covers, try using 4 0000steel wool with Simichrome alumium polish, try on 1 end first. I used it on my rims on my vette and you cant see any scratches.
If you have a old electric motor you can get the attachments and pads from www.eastwood.com or a drill attachment.
Luv the smell of NITRO in the morning.
