valve covers - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-14-2006, 10:40 PM
cardaddyo's Avatar
always the hard way...
valve covers
i have aquired a set of late 50's embossed valve covers(cool straight bottom edge chevorlet).i have vortec heads,so no direct bolt-on.jegs has an adptr to fit these heads so i could use the covers,i believe its around $130(#555-50120),has or does anybody use these?pros-cons?thanks
Old 02-15-2006, 04:44 AM
302 Z28's Avatar
I have the adapters, bought them off Ebay for $65. Haven't used them yet, but know plenty of people who have and they are no problem. There are two types out however. One uses an large O ring at the adapter to head mating surfaces. The other and less prefered method uses a gasket. The O ring type is made by GM Performance Parts.
Vince
Old 02-16-2006, 01:25 AM
cardaddyo's Avatar
the gm parts is what i also had in mind.thanks for the o-ring tip,mind is made up.thank you ,vince
Valve Lash adjustment hiball Engine 36 05-11-2009 10:12 AM
after market valve covers Kevin64 Engine 7 06-22-2003 01:56 PM
after market valve covers Kevin64 Engine 0 06-21-2003 08:47 PM
after market valve covers Kevin64 Engine 0 06-21-2003 08:09 PM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
