Valve Covers - Aluminum vs. Chrome - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 07-24-2006, 11:15 AM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Good thick gaskets with hole gromets are available for many applications. Not cheap but work well.
  #17 (permalink)
Old 07-25-2006, 01:00 AM
The yellow 3M stuff is great for stuff that you don't want to take apart for 20 years or so, but if you need something that releases easily, you need something like Permatex #3, or #2 if it needs to be a little stiffer/stickier. I use both on cork valve cover gaskets, 3M on the cover side & #3 on the head side.
  #18 (permalink)
Old 07-25-2006, 08:24 AM
you want a good sealant for gaskets... or no gaskets... loctite gasket eliminator / flange sealant... they changed the red goopy stuff to a thinner pink mix... but it still works very well, just not for sealing LARGE gaps anymore... does not setup until heat cycled... thin line on a felpro rubber impregnated fiber gasket and no leaks.. ever... unless you push the gasket out of the joint
btw, aluminum all the way...
everyone have a good week eh.
J
Fake Hemi Valve Covers Chev37 Engine 10 01-27-2006 04:13 PM
Short valve covers too tall... ChevApache59 Engine 11 12-06-2005 07:05 PM
harland sharp / 1st gen / valve covers darom Engine 3 08-02-2005 07:11 PM
How do I paint ball milled valve covers JeffShuman General Rodding Tech 3 08-10-2004 09:56 AM
Re: Roller Rockers, Stud Girdle - Which Valve Covers? jerseyjeff Engine 5 11-07-2003 05:07 AM
