valve covers blown off - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-19-2006, 04:05 PM
Do you guys remember the guy that said he had his valve cover blown off ? He did not lie, I have a 355 supercharged engine. Knowing that I had two fuel glass low in fule, I tried to start the engine, Big back fire. I blew off both valve covers, the dip stick, and the master cylinder clamp. I also have breathers on both sides of the valve covers, I must check the flote bowls.
Old 04-06-2006, 07:59 PM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
I have got to ask this question............. were the covers bolted on, what are you smoking and how beers have you had 2 ????
Old 04-06-2006, 08:33 PM
Siggy_Freud's Avatar
I dont really understand how this would happen as the combustion events in the cylinder heads are seperated from what goes on under the valve covers by the valves. Unless you blew through valves I really cant see this happening.
Bringing history and technology together.
Old 04-06-2006, 08:44 PM
Warrant's Avatar
72 Nova, 65 Rambler, 37 Chevy
How bout some pics maybe?
Old 04-06-2006, 08:48 PM
Bumpstick's Avatar
Hammer and a torch
Now I`ve heard of your doors being blown off but the valve covers... Have to see that... If so I`d bet other gaskets like the oil pan and various oil seals cant be in to of shape...?
Old 04-06-2006, 09:18 PM
57 Chevy's Avatar
Daryl
Location: Montana, now Arizona.Now Colorado. Wish I was back in Montana
A little gas in the oil pan and the vapors raise to the top............The valve covers maybe.
Old 04-06-2006, 09:22 PM
blow the covers off
i don't know about the valve covers ... but i had a customer with a oil pan fire that blew every gasget out.. i had to pull the engine out..that fire burnt every drop of oil out of the pan.. what a mess .. finished with a full rebuild.. on a 350 sm blk
Old 04-06-2006, 09:26 PM
powerrodsmike's Avatar
Wiki Edits: 161
I was checking for spark one time on a car that wouldn't start and had become flooded. I was checking for spark by holding the end of the spark plug wire by the oil filler hole, (the oil filler cap wasn't on,), The spark worked and it shot a flame about 3 feet out of the hole. Made a big POP too. (kinda sounds like that gas fumes theory might be right)
Singed the hair on my eyebrows.
DOH!
mikey
BE different....ACT normal.
Old 04-06-2006, 09:33 PM
Thinking Man's Avatar
Let me think about that...
I've seen the valve covers blown off a 3406 Cat. That truck wound up being towed from Texas to the shop in Mississippi.
'57 Chevy - I like that shot of your car.
Old 04-06-2006, 09:43 PM
cat with covers
i never had much problem with valve covers on any of my cats... but i have 425cat here with a hole in the side big enough to stick your head in to see what went wrong ...i could laugh now but i cryed then
Old 04-06-2006, 09:58 PM
Yeah! About $18 grand worth of pain. That will bring a tear to your eye.
Old 04-06-2006, 10:10 PM
cry and kill
the driver was good enough to let me know where it was.. at the bottom of a big hill..in west va. nice of him...huh..maybe over-rev-ed just maybe..
Old 04-06-2006, 10:23 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
You should take a picture of that, I'd like to see it. Those are some pretty beefy parts to be chucking through the block. Did the driver mention how many rpm he was actually spinning the thing?
Old 04-06-2006, 10:52 PM
valve covers
i don't know how fast he spun it ..but he was smart enough to not come back for his last check ....i could tell you more damage stories about drivers.. funny but sad because it always comes out of my pocket i had a cummins 444 with a droped valve.. driver said it was my fault because it ran to fast...that one was half up the next hill...the driver said it made a loud noise .........one thing forsure he's not a liar...
Old 04-08-2006, 05:59 AM
Hey pepi, siggy Freld, Warrant and Bumpstick. If you guys don't believe me, one of the valve covers is at SHORE MOTORSPORTS, INC Howell NJ. 732-364-7997.
small block Ford valve covers Da' Bomb Engine 0 09-11-2004 07:44 PM
Installing studs for valve covers Jag Daddy Engine 11 07-09-2004 10:26 AM
348-409 valve covers Scuzzy Engine 2 08-08-2003 12:45 PM
Valve covers Hellzapoppin Engine 2 06-23-2003 09:37 AM
after market valve covers Kevin64 Engine 0 06-21-2003 08:47 PM
