valve covers won't clear stud girdle! - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-17-2011, 02:15 AM
Jason7504's Avatar
I have a 468 with B&B stud girdles on it and I got some Summit brand tall aluminum valve covers but the valve covers wont clear the stud girdle. I think the bolts/poly locks on the stud girdle are the reason. what does everyone else that runs stud girdles on similar sized engine use with stud girdles?
I'm going to return the summit ones and I ordered these Dart covers that might work. Anybody used them or know if they will fit? at the very least, i could grind them a little since there steel and not alum if they still don't fit.
http://www.summitracing.com/parts/DRT-68000060/
Old 03-17-2011, 03:43 AM
SSedan64's Avatar
Have you tried Thick gaskets or double gaskets?
Old 03-17-2011, 03:51 AM
sqzbox's Avatar
My pipes are my music
No baffles, no breathers, no grommets, I'd pass on that.
Old 03-17-2011, 01:38 PM
Jason7504's Avatar
well i'm gonna use the silicone with steel core gaskets and I already have breathers for it but I don't think baffles would clear
Old 03-17-2011, 01:59 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi
When Jenkins ran the BBs he used stock valve covers w/spacers & the droppers ground off.
Rich
link for spacers at summit
http://www.summitracing.com/search/?...0spacers&dds=1
Old 03-17-2011, 02:14 PM
Jason7504's Avatar
so with tall valve covers, would I need just to ground off the droppers?
Old 03-19-2011, 06:20 PM
Jason7504's Avatar
ok well i tried some Dart valve covers that are supposed to clear stud girdles but they didn't because of the baffles. I would take them off but then I couldn't return them if they didn't fit. Anybody else running stud girdles?
Old 03-25-2011, 07:46 PM
Jason7504's Avatar
here's a pic for reference?
I ordered some Moroso tall valve covers that somebody else used over stud girdles..hope they fit!
Old 03-25-2011, 09:29 PM
ericnova72's Avatar
More for Less Racer
Does the cover hit the girdle bars, or the top of the rocker arm nuts??
You usually have to run the girdle as low as you can get it to the rocker arm body's while still clearing them to keep the rounded upper corners of the valvecovers from hitting the girdle bars. From the looks of your pictures you could lower the girdle bars an 1/8" or maybe more.
On a different issue, you may have trouble with the intake to head seal with the Permatorque Blue intake gasket you are using. It's material conformability is made for iron intakes to iron heads and tends to leak after a period of use with aluminum intakes. Correct gaskets for use with aluminum intakes would be from the Fel-Pro Print-o-Seal line, Edelbrocks own brand line, or Mr Gasket. These three are all fiber based gaskets with a silkscreened silicone bead on them.
Old 03-25-2011, 09:40 PM
001mustang's Avatar
fwiw. i've seen fabricated valve covers on ebay. if no joy, you may contact an ebay vendor for dimensions.
did you happen to measure RA stud deflection prior to girdle install?
looks sweet btw. shame no clear vc
Clear Valve covers? Optik Hotrodding Basics 12 04-02-2014 05:32 PM
Clear coating valve covers 302 Z28 Body - Exterior 4 08-21-2006 10:20 PM
Clear valve covers Ktaves1971 Engine 3 01-19-2005 07:57 AM
Re: Roller Rockers, Stud Girdle - Which Valve Covers? jerseyjeff Engine 5 11-07-2003 06:07 AM
Anyone know where to get Clear/see through SBC valve covers?????? Blown72Camaro Engine 1 08-29-2003 03:46 AM
