valve lash - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-09-2009, 09:24 AM
valve lash
hey guys
can anyone tell me what the valve lash would be on a 1963 ford falcon 170 cu in six banger?
Old 02-09-2009, 09:27 AM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
Look in the Knowledge Base, it has the info.
http://www.hotrodders.com/kb/valvetrain
Luv the smell of NITRO in the morning.
Old 02-09-2009, 09:32 AM
Thanks 1bad80
I guess maybe I should have said what should they set at ( .012ex .016in etc etc)
Old 02-09-2009, 05:18 PM
woodz428's Avatar
Troll Hunter
I can answer that, but first.. the name of the forum is Hotrodders...not tune up specs. If you had looked at ANY manual,Chiltons, Motors or any number of others, you would have gotten the answer in the minute or less it took me and I haven't had one of those engines for over 30 years. Why do people feel it is neccesary to waste others time getting info that is generally available almost anywhere..even on the internet( there are plenty of 6 cylinder forums).It is EXACTLY these types of posts that has generated the long thread in the general discussion section "engine forum is getting out of hand". It's fine to ask questions regarding info that isn't easily found, but come on ,valve lash specs on a stock engine??? If it was some aftermarket cam that you had no idea where to find the specs, maybe someone here could research it and supply info...BUT stock tune up crap?? This doesn't even belong in the basics section, it belongs at a local garage or library and DEFINITELY NOT in the engine section. Buy a service manual..you apparently need one..the specs are .016C I&E.
Old 02-09-2009, 05:57 PM
thanks woodz428
thanks for the info. sorry I offended you. I could say more but it is always easy to say thing a loud on here or a phone. again thanks
Old 02-09-2009, 06:06 PM
1BAD80's Avatar
Wiki Edits: 2
It is also in the Knowledge Base if one looks.
Old 02-09-2009, 10:03 PM
woodz428's Avatar
Troll Hunter
I kind of figured that too, hence my seemingly gruff comments. I looked at the time you posted and the time he re-posted, then took a minute to look at the link and figured that he must have not spent anytime looking there.
It wasn't my intention to unload on him, more of an address to ALL the questions that can be answered elsewhere and should with just a wee bit of effort.
Correct way to set valves on sbc w/ solid flat tappit camshaft? Joshua Lee Engine 17 02-09-2011 06:55 PM
700R4 Why are the TCI manual valve body instructions so lousy? Bayley Transmission - Rearend 24 02-16-2009 01:49 PM
Reducing Valve Lash on Solid Roller - Is It Ok To Do? leejoy Engine 13 12-19-2008 11:11 AM
Valve Lash???? Help haley72 Engine 19 03-10-2007 01:13 PM
GM fast burn heads batman09 Engine 1 10-26-2004 10:32 AM
