Valve lash - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-24-2003, 08:47 AM
Sampson's Avatar
Valve lash
Can someone help me with the valve lash on a sbc 400 hydro lifters stock rockers .
Thanks
Old 08-24-2003, 09:50 AM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
There have been numerous post on this subject, please look in the Knowledge Base or Search this Forum at the lower right side.
Heres the site,
How to Set Valves the Easy Way
http://www.chevyhiperformance.com/te...lve/index.html
Luv the smell of NITRO in the morning.
Old 08-24-2003, 03:38 PM
JoeS's Avatar
If you set the lash with the engine running make sure you buy some oil clips that go over the top of the rocker arm to control the oil. Otherwise you'll have a big mess
Old 08-24-2003, 05:20 PM
MI2600's Avatar
Member# 3287
I set my valves initially, with the engine out, by going to TDC on #1, using the "spin the pushrod" method. You can set both valves. Then rotate the engine 1/4 turn and adjust #8. After that rotate the engine 1/4 turns and follow the firing order.
After the engine is running, I set them again. Loosen each rocker until the rocker "clacks". Then slowly tighten until the clacks stop and go another 1/2 turn (some say 3/4 turn).
You'll probably not enjoy the smoke on the exhaust manifolds (I remove the battery from the smoke detector), but that's part of being a gearhead.
Old 08-24-2003, 08:27 PM
87 350monteSS's Avatar
Monte Super Slow
sometimes i wonder what the neibhors are thinking when i am under the hood working and its smoking oil on the headders hehe
