valve lash??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-21-2002, 12:17 AM
chevyelc81's Avatar
Post valve lash???
on an early 350 with an after market solid lifter cam, what should the valve lash adjustment be. Im not sure what kind of cam it is, but its slightly radical and its high performance. All the books I have just tell me to adjust lash to factory or cam specs, but I need numbers. Help please????
Old 06-21-2002, 08:46 AM
F-1Rodder's Avatar
Post
I'm no expert on this, but I believe you should go to the manufacturer and get their advice.
Old 06-21-2002, 09:31 AM
E.T. divided by $ spent= Speed
Post
You can get cam cards online off a cam company website.www.cranecams.com <a href="http://www.compcams.com" target="_blank">www.compcams.com</a> Maybe that'll help.
Old 03-29-2009, 06:58 PM
valve lash
i race a bbc solid lifter valve lash 28 to 30 in & out
Old 03-29-2009, 07:01 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
You won't be too far out if you lash 'em at 0.025".
Old 03-29-2009, 07:25 PM
How fast is fast enough?
I'd go even a little tighter than that, like .020" but if its an older cam .025" is probably pretty close to factory specs.
