Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Valve Lash
Thread: Valve Lash
Old 10-04-2007, 06:11 PM
Blazin72's Avatar
Blazin72 Blazin72 is offline
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
Ditto on wiggling the rockers. If you're spinning the pushrod you should begin to feel a light drag when trying to spin it, not necessarily so tight it won't spin.
When you adjusted them did you make sure you were at #1 TDC compression and not on the exhaust stroke? You can verify #1 TDCC because #6 will be in overlap. When you went to the second set of valves did you rotate the engine one full turn before starting?
