Valve lash changing, sbc! - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-19-2004, 05:21 PM
Never had this problem B4 so any ideas would be appreciated! 291 heads have been redone with screw in studs & roller tip rockers, locking adjust nuts & double valve springs (Crane), Summit hydraulic cam/lifters 234-244@.050 but when I set the valve lash cold, it runs ok for a few miles then I hear clacking. So, pulled the valve covers & set them hot by backing off until the clacking starts easing them until it stops then 1/2 turn down. By the time I get to the #7 # 1 is clacking again! Did it again & again & seemed ok then after 100 miles clacking & ROUGH idle again! Whats up???
Old 09-19-2004, 06:03 PM
Sounds like the camshaft was NOT properly broke in and MAY be going bad.
Old 09-19-2004, 06:08 PM
poncho62's Avatar
Wiki Edits: 5
or......Bad lifters.
Old 09-19-2004, 06:14 PM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
Arrow
I would not start the motor anymore until the lifters are taken out and inspected for ware or anything else out of the norm.
Luv the smell of NITRO in the morning.
Old 09-19-2004, 07:16 PM
Originally posted by Deuce
No, thats not the problem as the cam & lifters were broken in with the original build & reinstalled when I put the new (to me) heads on.
Old 09-19-2004, 07:21 PM
When you put the cam in after the head swap, did you put the lifters on the cam lobes they were originally on?
Old 09-19-2004, 08:43 PM
GoneNova/406's Avatar
when you primed the oil pump before starting it after working on it each time,did it have good oil pres..your're sure there is oil all the way up to the lifters.
Old 09-19-2004, 09:11 PM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
you can sit and speculate all day long about what's going on. First thing to do is yank the intake and check your lifter bottoms. IF you're not surepost pictures of all 16 on here. Make sure you keep track of where all the lifters and pushrods go!
K
Old 09-20-2004, 07:40 PM
I've done all these suggestions B4 posting but still problematic! Got really focused on individual changes & find that there are only three that keep changing. Has anyone had problems with Summit lifters?? I can set these 3 the same as the other 13 but they change and clack after a turn around the block! The rest are fine!!
Old 09-20-2004, 08:06 PM
edge's Avatar
Time is short, are you ready?
Summit Cam & Lifters
Yes!
Pretty sure the cams are ground by Crane, but not sure about the lifters. Two cams in two different engines and both had problems. Maybe it was me , but I will not buy another Summit cam & lifter set.
I went hydraulic roller in my last engine to avoid the hassle of flat tappet problems Good luck, Ed www.edgesz28.com
Old 09-20-2004, 08:25 PM
Wiki Edits: 3
i've run them and never had a problem. LIfters are supposed to turn in the block.
K
Old 09-21-2004, 07:57 AM
K
No, no I meant driving the car around the block and these three start clicking again. Now I'm wondering about replacing the whole set with newbies from Crane or Comp as I guess i can lube the lobes with cam break in lube leaving the cam in place as I don't want to take 1/2 the front of car apart to pull the cam.
Old 09-21-2004, 10:16 AM
edge's Avatar
Personally, I would not put new lifters on a used cam. I am sure it has been done countless times successfully; but to me, it is not worth the chance.
My last cam had two lifters that were not spinning. They had not wiped at the time I pulled the intake and inspected the lifters, but the tell-tale signs were there. Below is a picture of one, you can clearly see that the lifter was not rotating. Note - the bottom was smooth, but there is reflection at one corner, so it looks worse than it really was.
I would pull the intake and inspect the lifters as killerformula suggested earlier. If you find any problems, I would replace the cam and lifters, and consider a hydraulic roller. Yes it is costly, but think of the money and aggravation saved by having to replace another flat tappet cam (if you have another problem). And more importantly, the piece of mind knowing the lifters (and/or cam) are not the problem.
Good luck, Ed. www.edgesz28.com
