valve lash mishap - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 01-09-2011, 08:18 AM
68NovaSS's Avatar
Wiki Edits: 9
Originally Posted by DLock
...my paltry 305 pulled 625hp/572lbs back in Hawaii (when it was tuned well but had lots of cooling issues)...
With all the interest here in budget 305's, we'd love to see the build details...and dyno sheets. Can we assume this is the same Camaro and motor?
  #17 (permalink)
Old 01-09-2011, 09:06 AM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
X2 show us the sheets.
Cole
  #18 (permalink)
Old 01-09-2011, 09:25 AM
Custom10's Avatar
my KARMA ran over my DOGMA
Last journal entry: SS
625hp engine on autozone beater pushrods no less... good thing you bought 4, I'll buy tickets to that dyno pull
TJ
  #19 (permalink)
Old 01-10-2011, 02:40 AM
Build Sheet
1989 Iroc-Z/28
305 (.030 over), Forged 2 valve relief pistons(not sure specs), Comp Cam (also not sure specs), AFR 190 Heads, TPIS Intake, Lingenfelter Throttle Body, Paxton SN-92 Centrifugal Supercharger, Holley Pro Commander 950 Fuel/Spark Mapper, All MSD Ignition (Dist, Coil, MSD, Wires, Boost Timing Retard, etc), (not positive on the Injector Size), NGK 2 step colder plugs, LT1 Headers, 3.5" Exhaust (no cat), Borg Warner 5 spd tranny w/ hurst shifter & 3.73 Rear gear (not sure the clutch specs either). All the work was done by another guy before me and the previous owner before him (he was getting deployed so I bought the project off him but that explains the unknown specs parts) I was getting it tuned to work out the start-up, decelerating and 5th gear throttle response problems. Tuning was about 80% complete (I was getting work done in segments as the $1000 total estimate upfront is alot of loot when u have 4 kids) before the head gasket blew (on the road not the dyno.) When I get it back in order and ready for tuning I'll get you a slip from here in Maryland (as I'm no longer stomping around in Hawaii so I can't just walk into Ron's Performance and ask for a printout from April) Sorry if that sounded like a dick didn't mean it to come off that way. Trust me I wouldn't believe me either if it wasn't for the fact that I've driven the monster. O and it's far from Budget Build as the previous owner claimed to have dropped a total of 15 1/2 grand on the car. Which from the list of parts you can see is fairly accurate (SN-92= $2600, AFR Heads= $1600, Pro Commander 950= $1600, just to name a few let alone all the suspension upgrades.) To be honest the car has caused more headaches then anything though. Start-up is always a 5 minute process, if it hasn't been started in 24 hrs is acts like a baby, and at 8mpg I'm not daily driving her. Besides every part I needed back in Hawaii was special order because they're Honda/Toyota territory. P.S. Any suggestions on some "spark plug change friendlier" headers? It's almost impossible with these damn things.
Correct way to set valves on sbc w/ solid flat tappit camshaft? Joshua Lee Engine 17 02-09-2011 05:55 PM
Valve adjustment with hydrulic lifters David77nova Engine 4 11-13-2010 03:00 AM
700R4 – Why are the TCI manual valve body instructions so lousy? Bayley Transmission - Rearend 24 02-16-2009 12:49 PM
Reducing Valve Lash on Solid Roller - Is It Ok To Do? leejoy Engine 14 12-19-2008 10:11 AM
GM fast burn heads batman09 Engine 1 10-26-2004 09:32 AM
