Obviously you have exhausted all routes to determine what you have.
Is it running well now? Does it sound OK now? I would measure the clearances cold and note those figures and make adjustments based on that. Monitor a vacuum gauge closely to determine if the valves are closing when it gets hot. If the engine is not runable now, I would pull the valve covers and measure what the clearances are now, right off the dyno. Surely the engine assembler got the clearances close. Most everything will be in the 20/20 range, give or take a couple. Note= it takes a very good human to get the valves within .002 with a hand feeler gauge. |
cam
It all depends on how good you are with a indicator...
Solid cams have what is called a lash ramp ground into them. The lash ramp is usually close to what the valve lash is... You are going to have to check it down on the lifter. If you rotate the engine until the lifter is on the base circle of the cam and then set the indicator to zero...rotate the engine in the normal direction and watch the indicator real close, as the needle starts to move you will see it move slow at first and then faster when it starts on the opening ramp... do it a few times and you will catch on to it... If the lash ramp is say .020" i would start with a lash of about .022" or so... don't lash it less then the ramp.... Keith |
Thanks
Thanks for the replies - I'll check the lash as it is now - it's running good but I'm starting to hear a little valve train clatter. I'll try the indicator method next time I have the intake off.
Hope you all had a good 4th... Mike |
| valve lash??? | chevyelc81 | Engine | 5 | 03-29-2009 07:25 PM |
| SBC 350 Valve lash !¿?¿ | boneyard Buick | Engine | 5 | 11-09-2005 08:21 AM |
| Best way to install valve cover gromits. and breather question? | Jag Daddy | Engine | 1 | 05-03-2004 03:20 AM |
| If the valve lash is off.... | KeithB123 | Engine | 2 | 09-21-2003 06:30 PM |
| Valve lash | Sampson | Engine | 4 | 08-24-2003 07:27 PM |
