Valve Lifters Escort Lx - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-25-2007, 07:12 AM
Can any one please help me on how to bleed the Valve Lifters on Ford Escort Lx 1.9Lit. Engine?
Thanks;
Alcan
Old 06-25-2007, 09:10 AM
The only thing you can do is let it run till they pump up.If these are not new and noisy they will probably need replaced.
Old 06-25-2007, 02:49 PM
Thanks Barnym17 for your reply.
The reason I want to bleed the valve lifters is that it seems it has to much pressure in it, that it holds the valve open in cylinder one during compression and not giving power to the piston. I check the rocker arm and it seems to be hard and no play, while the rest of the racker arms has play on it, when they are on TDC.
Old 06-25-2007, 08:33 PM
King of my Man-cave.
You can take that lifter out and squeeze it in a vise. It may take a couple of times to get the oil out. Make sure the spring pushes the plunger back up all the way. You should be able to squeeze it by hand at this point. You may have to spray some carb clean in it to free it up.
It would probably be easier to just stick a new lifter in it.
tom
Old 06-27-2007, 09:48 PM
Just got my valve lifter replaced with new one, but still the valve does not give any play, and it push down the lifter so hard at compression with piston at TDC, any idea which could be a problem? Do you think it might be a valve spring causing too much pressure, or the valve are already worn out?
Thanks;
Alcan
Old 06-28-2007, 12:06 PM
Make sure the little shim underneath the rocker pedestal is in place.
tom
700R4 Why are the TCI manual valve body instructions so lousy? Bayley Transmission - Rearend 24 02-16-2009 01:49 PM
So what is a valve job............? machine shop tom Hotrodding Basics 6 02-15-2006 10:25 PM
Brake Proportioning Valve Linkeage Adjustment awbazar Suspension - Brakes - Steering 5 02-03-2006 04:08 PM
PCV Valve Problem Steve karch Engine 5 09-08-2004 07:00 AM
When Should one Install Dual Valve Springs on OEM GM BB Auto-Part Engine 7 11-29-2003 06:35 AM
