Valve/Piston Clearance - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-20-2008, 08:07 PM
Im building a 327 ci small block chevy and Ive got another quick question.
The pistons have a small D shaped dome and shallow flycuts. Might be the old 11:1 pistons? The heads are '642' castings. 76cc chambered boat anchors.
Isky cam - .505 lift, 292 duration, 244 @ .050.
1.5 ratio rocker arms.
Will I run into valve/piston clearance trouble with this setup?
Old 02-20-2008, 08:12 PM
techinspector1's Avatar
Wiki Edits: 326
Nobody can say definitively. Depends on whether the block has been cut, the heads have been cut, how far the valves are sunk in the heads, piston deck height, gasket thickness, rocker arm ratio (actual) and etc., etc.
Scroll down to "How to check for clearance between valves and pistons"
http://www.iskycams.com/camshaft.php
Piston To Valve Clearance Problem - Help leejoy Engine 85 02-24-2008 07:12 PM
Piston To Valve Clearance Question # 258,325 leejoy Engine 4 01-07-2008 06:40 AM
700 clearance question Jmark Transmission - Rearend 3 05-24-2006 10:17 AM
Clearance Problem Ratoflic Engine 2 12-07-2004 02:26 PM
TH 350 Intermediate clutch clearance 1969Chevelle Transmission - Rearend 1 08-26-2003 05:34 PM
