Valve to piston clearance - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-24-2003, 07:21 PM
Stinky's Avatar
I have a 69' Pontiac 400 with A/T, A/C
The heads are stock.
I put a cam in with lift at valve: Intake .420"
Exhaust .442"
The stock valve lift is: Intake .410"
Exhaust .413"
My question is will this setup work with using stock heads??
( I havent the I.D. numbers on the heads)
Old 07-24-2003, 08:04 PM
DoubleVision's Avatar
it should be just fine, I wouldn`t worry about a step bigger cam running into any problems.
Old 07-24-2003, 08:19 PM
lluciano77's Avatar
Re: Valve to piston clearance
Exhaust .442"
Exhaust .413"
I think you are safe to at least .480" lift on a Pontiac 400. A lot of times the springs are worn out on rebuilt heads. If you want you can always change the valvesprings. This would be for reliability not because of clearance, and get a spring rated for .500" lift. They should be pretty cheap.
Old 07-24-2003, 08:44 PM
4 Jaw Chuck's Avatar
If you put it in already you would know? Wouldn't you? Is it running already?
— Han Solo
Old 07-24-2003, 08:50 PM
dmorris1200's Avatar
doesn't play well with others
Good point Chuck.
BUILT FORD TOUGH
Old 07-24-2003, 09:03 PM
NAIRB's Avatar
Maybe he hasn't fired it up yet. Anyway, the cam he has isn't much more than stock , but I will say this about a Pontiac, the factory springs are weak, and they only install around 1.600" so they don't tolerate alot of valve lift, and even if they don't coil bind, you won't have much spring pressure which means you won't be able to twist it very tight before valve float occurs. I recommend a spring upgrade with any type of performance Pontiac cam.
Old 07-24-2003, 09:18 PM
Just havin' a little fun there Nairb. I'm sure Chuck thought the same thing I did after reading his post. Wouldn't most people check to see if a cam would work in their engine before they (A) bought it, and (B) installed it? Either way I thought it was kinda funny.
BUILT FORD TOUGH
Old 07-24-2003, 10:31 PM
Stinky's Avatar
I did replace all the springs with the performance stock type and put in new seals. Just trying not to get any surprises, covering all the bases.
Be gone, this board is for technical help. The next time you land youre getting swatted.
Old 07-24-2003, 10:38 PM
NAIRB's Avatar
VALVE TO PISTON CLEARANCE
Stinky, it's always a good idea to mock up your engine and "clay up" a cylinder just for safety's sake. With the cam you have selected, you should be just fine. However, for your own peace of mind, mock up one cylinder head, put some clay on one piston and get ahold of one solid lifter to cycle your cam through it's lift cycle, then measure (if any) how much your clay was squashed. As noted before, you should be fine and dandy with your mild cam.
Old 07-24-2003, 11:24 PM
lluciano77's Avatar
Yeah, and don't forget to check your oil pressure before you start your engine! Sorry Stinky I'll leave that one alone from now on.
Anyway, just fire it up it will be fine at that lift.
Old 07-25-2003, 12:57 AM
Check oil pressure?
How do you do that?
Actually any cam off the shelf will fit any engine with no interference problems whatsoever. Thats why you never need to check these things before installing them. If I am in doubt I just install the cam and worry about the consequence's later. You did deburr the cam before you installed it right? Bearing clearances?
No!? Ahhh, don't worry about it. Just another thing to slow ya down.
Your not mad at me are you Stinky? Please accept my deepest apology's...sniff...sniff.
— Han Solo
Old 07-25-2003, 07:50 AM
NAIRB's Avatar
Old 07-25-2003, 08:16 AM
Frisco's Avatar
Glad To Be Here
Exhaust .442"
Exhaust .413"
I have a suggestion for you. Before making modifications, read the instructions, get a book or books on what you want to do. Talk or write to the manufacturers. Learn before you do. It will save you both time and money and you won't get so much 'Flac' from others.
Old 07-25-2003, 09:09 AM
gt2betubbed's Avatar
Kid With A Wrench...
Last journal entry: The Blower and test fit.
deburring?
Hey 4 Jaw, what do you do in order to deburr the cam?
Old 07-25-2003, 09:11 AM
Stinky's Avatar
And it still continues. Tech board, tech help. Makes me wonder who the moderators are.
I did read the instructions and have books, like i said at first i just wanted to double, double check.
