valve to piston clearance - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-18-2012, 10:56 AM
I have a Small Block Chevy and would like to know what the acceptable piston to valve clearance should be. I'm using a Hydraulic Cam with a .512 lift
Old 01-18-2012, 11:11 AM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
I think I remember hearing like .080" on the intake and .100" on the exhaust. Not 100% sure but it should be around those figures. the more the better lol
Old 01-18-2012, 11:27 AM
techinspector1's Avatar
Wiki Edits: 326
Scroll down on this page to....
"WHAT IS THE V/P SAFETY MARGIN?"
http://www.iskycams.com/camshaft.php
Old 01-18-2012, 02:47 PM
[QUOTE=zildjian4life218]I think I remember hearing like .080" on the intake and .100" on the exhaust. Not 100% sure but it should be around those figures. the more the better lol[
/QUOTE]
Thanks you were right on the Money according to an Isky Rep
Old 01-18-2012, 03:02 PM
Listen and Learn
Wiki Edits: 7
I just helped my machinist check his clearance a couple weeks ago so It was still fresh in my memory lol.
Old 01-18-2012, 07:01 PM
You can go a lot tighter than that if your valvetrain is built with quality matched components. Having it set at .080" intake and .100" exhaust is very safe and will take into account an overrev or 2 and a flexing pushrod, or marginal springs. The most important part is the valve spring. Make sure you run the spring intended for the camshaft you have, and make sure it is installed at the proper height so it can do its job.
Piston to valve clearance on BBC ja1758 Engine 1 06-25-2011 05:20 AM
86 302 piston/valve clearance kobra_428 Engine 5 11-12-2007 01:08 PM
piston to valve clearance. 85 regal Engine 1 04-13-2004 08:09 PM
piston to valve clearance crazyman Engine 7 02-22-2004 03:52 PM
valve to piston clearance dgkipp Engine 2 01-15-2004 07:01 AM
