Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - valve seals
Thread: valve seals
Old 02-13-2012, 09:47 PM
tbrown8338 tbrown8338 is offline
Originally Posted by skip99
use one or the other.....and I always used air with a scrrew in fitttng into the sparkplug hole, remove all the plugs apply air and the air will spin the motor, piston down and hold valves closed while you change them..
will hurt if i used both
