I have both seals on some old GM 882 smog heads. These where installed 2 yrs ago. I had some oil consumtion issues and found the valve guides to be worn sucking oil into the cylinder heads. My temp fix was to install both seals to cut down on the oil use. Some prev. owner installed 1.6 roller tip rockers. This fix did cure my oil use. Hope this helps
