valve seals - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-12-2012, 04:11 PM
valve seals
can someone tell me how to replace the valve seals (umbrella) on a chevy 350 engine. where does the o ring goes top or bottom of the unbrella seal.
Old 02-12-2012, 07:22 PM
techinspector1's Avatar
Wiki Edits: 326
http://www.ehow.com/how_5374175_inst...ls-engine.html
Old 02-12-2012, 07:33 PM
skip99's Avatar
use one or the other.....and I always used air with a scrrew in fitttng into the sparkplug hole, remove all the plugs apply air and the air will spin the motor, piston down and hold valves closed while you change them..
Old 02-13-2012, 09:47 PM
will hurt if i used both
Old 02-14-2012, 11:14 AM
The O ring is used on the stem when the valve assembly includes a stamped metal shroud under the retainer, covering the top of the spring and a coil or two on the side, it diverts oil away from the guide. The purpose of the O ring is to keep oil that puddles in the locks and retainer doesn't run down the stem.
The umbrella seal replaces both the metal shield and the O ring providing both the functions of diverting the oil away from the guide and stopping its flow down the stem.
There is no need for both the O ring and the umbrella seal.
If you're running a higher lift cam or 1.6 rockers check the clearance with the valve fully open between the bottom of the retainer and top of the seal. If the seal gets squished in there it function is lost.
Bogie
Old 02-15-2012, 04:47 AM
valve seals
Bogie
i had already put both the oring and the umberalla on before i read this. would it cause any problems
Old 02-15-2012, 06:12 AM
81 Vette
I have both seals on some old GM 882 smog heads. These where installed 2 yrs ago. I had some oil consumtion issues and found the valve guides to be worn sucking oil into the cylinder heads. My temp fix was to install both seals to cut down on the oil use. Some prev. owner installed 1.6 roller tip rockers. This fix did cure my oil use. Hope this helps
Old 02-15-2012, 10:59 AM
The big issue with both is to be sure when the valve is at the peak open position the seals aren't being squished between the top of the valve guide and the bottom of the spring retainer. If the seal and O ring do get squished it will do nothing more than ruin the sealing capabilities, hard parts will NOT suddenly come flying out.
If the heads are on the bench this is easy to check with the valve spring removal tool, by putting a thick spacer over the installed retainer and valve stem so when you compress the spring the valve opens instead of the retaining being depressed to release the locks. Then with a machinists rule little 6 inch stainless job measure the height till you get to where the rocker would have the valve fully open. Then observe the clearance of the seal and O ring as it rests between the guide and retainer. Anything equal or greater than .050 inch is plenty.
Bogie
valve seals for tbrown8338 Engine 2 02-12-2012 09:00 AM
How to tell if valve seals are bad Bonhorst Engine 4 01-13-2010 08:22 PM
Valve seals DoubleVision Engine 9 03-09-2009 07:32 PM
Why don't my valve seals fit? maxpower_454 Engine 18 01-08-2009 10:15 AM
Can the dual coil valve springs on a BB destroy Valve guide seals Auto-Part Engine 4 11-25-2003 06:23 PM
