-   -   valve seals (http://www.hotrodders.com/forum/valve-seals-225921.html)
69novassguy 11-09-2012 08:36 PM
valve seals
so ive narrowed down a sigle plug fouling out to a bad valve seal...i have a 69 nova ss with a 350sbc and was wondering is it possible to replace without taking the heads off? has anyone done it?
cdminter59 11-09-2012 11:04 PM
valve seals
Are you sure it is just the valve seal and not the guide? Hate to see you do all the work and it still leak oil and foul the plug. Any way here is a list of tools you will need: Summit Racing® Valve Spring Compressors SUM-906784 - SummitRacing.com, air compressor, Moroso Spark Plug Air Hose Kits 62385 - SummitRacing.com. Here is the tool needed to install positive stop valve seals: COMP Cams Valve Seal Installation Tools 5334 - SummitRacing.com. No installation tool necessary for umbrella style.
vinniekq2 11-09-2012 11:24 PM
Yes,and it can be done on the side of the road with a piece of flat bar,string,rag,hammer,socket.I dont recommend those tools but we did that at a race track when we had a broken spring,,,,between rounds,,,
the string can be used in the spark plug hole to keep valve from dropping. Hammer and socket to take spring off. I recommend you use a spring compressor for reassembly. there is also a spring compressor that reaches over the spring and has a turn knob on top that compresses the spring and has claws,think of a steering wheel puller principal
ssmonty 11-10-2012 04:28 PM
1 Attachment(s)
Here are some tools I've used to remove valve springs w/engine in the car. FWIW I had best results with the one on the bottom.
Good Luck
ssmonty
vinniekq2 11-10-2012 09:17 PM
the one on the bottom picture is what I was trying to describe.The middle picture is the tool we made out of a piece of flat car
cobalt327 11-11-2012 12:35 AM
The one w/the knob won't work w/double springs and heavy springs can be a problem. But it's OK for stock and mild performance springs.
Valve Spring Removal 101, Lesson 1: Loosen the locks before compressing spring. Use a large socket that will allow you to put force on just the retainer/spring and NOT the tip of the valve. In other words- hit the valve retainer- not the valve tip. A rubber mallet works fine, dead blow, fine- just do not use a steel hammer against steel. You can use a piece of wood atop the socket and hit THAT w/a steel hammer, if need be.
A cheap tool that will also work for mild springs. It goes over the stud, use a non locking nut to tighten the tool against the retainer, not a lock not or polylock you're going to reuse:
http://www.hotrodders.com/gallery/da...RESSOR_002.JPGhttp://www.hotrodders.com/gallery/da...RESSOR_001.JPG
And a more expensive tool for heavier springs:
http://static.summitracing.com/globa.../mor-62370.jpg
