Valve seals on an '89 Chevy 305 - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-25-2012, 04:29 PM
Not specifially a hot rod question, but I'm putting valve seals in an '89 Chevy pickup with a 305 for a friend in need. The seals look like the o-ring type. Is there a groove the o-rings sit in on the valve stem or do they push all the way down to the guide? Its been 20 years since I've done this and I honestly forget. Thanks.
Old 04-25-2012, 07:21 PM
LATECH's Avatar
Last journal entry: New Gas Tank
The O rings go into the lower groove of the valve stem as they seal oil from running through the retainer at that point. The keepers grab the upper groove to hold the retainer on the top of the stem.
Also dont you have umbrellas for the guide tops? Or did yours not use them?
Fact is stranger than Fiction
Old 04-26-2012, 03:25 AM
Thank you for the reply. I don't know about the umbrellla seals. Advance didn't list them so I'm assuming it doesn't use them (I hope!). I'm going to be doing this Friday so I don't have it apart yet.
Old 04-26-2012, 10:00 AM
BOBCRMAN@aol.com's Avatar
89 SBC's use a positive seal (FelPro Blue) that presses over the valve guide on the intake side and a white plastic umbrella on the exhaust. Plus the O-ring on the upper stem. Replacing just the O-ring seals will solve nothing. A waste of time. The later engines did away with the O-ring altogether as GM's existing inventory was depleted. Using the positive seal system exclusively.
Old 04-26-2012, 05:08 PM
Made sure I got the postive seals along with the o-rings. Thanks for the info!
52 chevy 216 inline 6 valve stem seals joebroni99 Engine 1 09-18-2009 03:03 PM
305 engine valve stem seals pablo Engine 4 11-21-2007 10:30 AM
chevy 350 valve guide seals wiretwister Engine 3 10-17-2007 07:36 PM
Chevy 235...valve stem seals? Slickriffs Engine 5 07-14-2004 05:43 AM
Can the dual coil valve springs on a BB destroy Valve guide seals Auto-Part Engine 4 11-25-2003 05:23 PM
