I assume the engine ran prior to the installation of the plug wires? If so then you probably have it wired wrong. Did you replace the wires 1 at a time? The wet plugs are most likely a result of your problem with gas all over the intake. The plugs are likely fouled from excess fuel and need to be at least cleaned and dried if not replaced. As far as valve seals, you can replace them with the heads on the engine, do not pull the heads for valve seals unless of course there are other issues such as valve sealing, valve guide wear, etc. If I have followed your repair process accurately I think this will help start the engine. Also, the typical symptoms of the need for valve stem seals is, a puff of oil smoke on start up after engine has been off for a while, oil fouled plugs and oil consumption.
I dunno. I went over the order a few times. the wires were clicked on firmly. I suppose ill get back over there and clean he plugs and try again but this plug fouling is getting annoying. I even swapped carbs a while ago because i thought the 750 may have been to blame.
it was brought to my attention that I may not be driving it enough to let the plugs reach the right temp so they are fouling. like they need to get hot and burn the stuff off. any opinions about that?
Put it in second gear and drive 90 mph.
Any side street will do. ![]() Afterthought. I see you have an HEI on your motor, what plug gaps are you using ? Last edited by malc; 06-10-2008 at 12:21 AM. |
| 700R4 – Why are the TCI manual valve body instructions so lousy? | Bayley | Transmission - Rearend | 24 | 02-16-2009 12:49 PM |
| Anybody dealt with this guy on ebay? Or through Dirttrackthunder.com? | killerformula | Hotrodders' Lounge | 20 | 08-31-2008 05:12 PM |
| cam question, any truth to this? | 406 ss monte | Engine | 9 | 03-30-2008 11:28 AM |
| Cam and Valve Spring help?? | 89SDime | Engine | 3 | 03-27-2006 10:46 AM |
| 87 octane engine cam swap? | 71C10 | Engine | 6 | 01-20-2006 10:50 PM |
