Valve Spring Compressor Tool - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-25-2011, 10:56 AM
Looks like I am going to have to replace a valve spring with a checker spring. The head has one spring inside another spring (dual springs) Comparing the two tools below which is better and easier to use?
http://www.summitracing.com/parts/SUM-906784/
http://www.summitracing.com/parts/WMR-W84002/
It's for a Pontiac 400, 6X heads, ARP 7/16" screw in studs.
Thanks,
BT
Old 09-25-2011, 11:43 AM
BOBCRMAN@aol.com's Avatar
I prefer the cheaper one. I've used them since the sixties. Simple and no parts to break..
Old 09-25-2011, 12:54 PM
When I saw the cheaper one I thought will it mess up the rocker arm studs during use? Suppose I could always wrap the exposed threads in tape to protect them.
BT
Old 09-25-2011, 01:44 PM
LATECH's Avatar
This would be my choice. It makes the job so much easier than the other designs.
http://www.summitracing.com/parts/OTC-4573/
onl a few bucks more, very well worth it.
It cranks down by a screw, holds the spring so you dont have to, makes things a lot easier, trust me.
It does not require use of the studs in the head.
WANTED: Valve Spring Compressor Tool for 85 Bird fla85tbird Garage - Tools 1 07-07-2011 10:33 AM
Flat head Valve spring remover Tool??? pk44 Garage - Tools 4 08-20-2009 09:08 PM
Valve Spring Compressor Tool Question leejoy Engine 9 02-27-2008 11:57 AM
Valve Spring Compressor Tool Help leejoy Engine 11 11-01-2007 11:24 PM
Valve spring tool 406chevelle Engine 7 04-03-2004 06:05 AM
