valve spring diameter - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-26-2008, 05:28 AM
when purchasing new heads what advantage does the larger valve spring have in a SBC with a mild cam lift ( under .470 intake and exhaust ) aftermarket cast iron WORLD heads thanx
Old 09-02-2008, 05:44 PM
None if not the proper spring for the cam. What do you mean by 'larger'?
Old 09-02-2008, 06:33 PM
The advantage is, if you ever swap cams for a larger lift one, you dont have to tear apart your cylinder heads to replace springs. That and maybe 500 rpms on the topside before valve float.
master cylinder interchange runn141 Suspension - Brakes - Steering 7 05-03-2009 05:15 AM
cam question, any truth to this? 406 ss monte Engine 6 03-30-2008 11:28 AM
Valve Spring Compressor Tool Question leejoy Engine 9 02-27-2008 11:57 AM
Valve spring ????? 66truck4spd Engine 1 08-25-2005 06:52 AM
Valve Spring Seat Question Garbonzo Bojangles Hotrodding Basics 3 01-08-2005 12:09 PM
