valve spring diameters - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-07-2005, 01:34 PM
matt_ramsey's Avatar
Your Basic Moron
Does anyone know what would be the stock valve spring diameter for a set of 80's 305 truck heads, and about how large of a diameter spring do you think they could accomodate? I have heard that 1.25" springs are easy to find, but I'm seeing a lot of 1.265" springs out there... How big can I go safely before I have to have the heads modified? Thanks!
-matt ramsey
Old 03-07-2005, 01:58 PM
johnsongrass1's Avatar
Race it, Don't rice it!
1.265 will fit. About $40 for a Z28 type spring. I would guess 1.55 would be the biggest single spring to fit.
Old 03-07-2005, 02:01 PM
Johnson has you on the right direction. 1.5" is about the largest you can go on stock heads without running into problems. OEM springs will be around 1.255 to 1.265.
Chris
Valve Lash adjustment hiball Engine 36 05-11-2009 10:12 AM
GM fast burn heads batman09 Engine 1 10-26-2004 09:32 AM
Broken valve spring??? Miligav383 Engine 6 05-16-2004 09:40 PM
broken valve spring dampner nastynova Engine 18 07-04-2003 09:28 PM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
