valve spring help - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-10-2011, 03:14 AM
valve spring help
I need help choosing valve springs for my engine. It is a stock bottom end 350 (flat pistons) with vortec heads. I have this roller cam from trick flow going in it
http://www.summitracing.com/parts/TFS-31402000/ i believe the cam pushes the limits of the stock vortec and am i need of need springs, any help in spring selection would be appreciated, thank you
Old 06-10-2011, 06:07 AM
Springs
In this case I always recommend a matching set Cam, Lifter, Spring, combination.This is purely cost effective for break in period and cam life. There are so many choices out there but they now have kits to eliminate your need to guess what is best and have our choice be the wrong one time or the set does not exactly measure up to what is recommended. There you have it tear down time new cam all the other crap associated with it as well. My advice purchase a matching set and install it all at the same time do not get the springs then cam and so forth. You may spend a little more at first but it is well worth the effort involved trust me.
Old 06-10-2011, 07:16 AM
SSedan64's Avatar
I agree^^^.
The Vortec springs aren't good for anything other than the stock Cam. There are other cheap Spring options that may work with that Cam but, you need to know the required Spring Specs for the Cam. Search through some of the other Vortec Head Threads.
Old 06-10-2011, 10:24 AM
Stock fit springs
A set of good valve springs for that camshaft would be Eldelbrock 5814. They are "drop-in" valve springs, meaning, they will fit the heads without any machine work to the guides or spring seats and fit stock valve length, with stock retainers and locks.
Single springs (no damper)
.480" max. valve lift
.530" max. valve lift @ coil bind
104 -116 lb. seat pressure @ 1.700" assembled height
1.250" O.D.
0.750" I.D.
Old 06-10-2011, 01:20 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Thar p/n is for a set of 12. The OP has a 350.
Old 06-10-2011, 01:22 PM
i already have the cam and lifters so i figure its more cost effective just to figure out the springs.
When i look up the Edelbrock 5814 it says they are for a v6 is that right?
Old 06-10-2011, 01:34 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
That p/n is for 12 springs and is correct if ordering springs for a six cylinder 2 valve per cylinder application. So, yeah. For a V6.
Have the heads been mocked up to see if they will allow the cam to be used, or are the heads already modified to allow for more lift than stock? That cam is about at the limit, lift-wise, so you need to check to be sure if they're stock head castings.
A common way to spring these heads is to use the "Z-28/LT-1" springs sold by most everyone and run them w/the damper removed.
HERE is a list of valve train points to check.
Info on Vortec heads and mods to them, etc. is HERE.
Old 06-10-2011, 03:35 PM
starting to seem like i should go with less of a cam since im trying to avoid machine work, i was hoping there would be a set of beehives to just solve the problem.
the info on vortec heads is helping alot
Old 06-10-2011, 03:44 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
There are beehive spring/retainer packages that allow more lift w/o machining.
Unmodified Vortec heads may have enough clearance for the cam you want to run- but you need to measure things to be sure, is all. Sometimes just a seal change can give enough extra clearance.
These- http://cgi.ebay.com/ebaymotors/VORTE...Q5fAccessories were asked about by a member here, never heard if he went w/them or not, though.
Old 06-10-2011, 06:09 PM
thanks, those springs seem like what im looking for just will have to mock the engine up and check the clearances then
Old 06-10-2011, 06:56 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If you use some checking springs, or even just assemble the valves into the heads w/a seal that you are going to use fully installed onto the guide boss, w/o springs and just use the retainer and locks, you can measure what the available spring height is. Allow for some clearance between the seal and retainer at max lift for safety sake and the rest is how much lift you can safely run.
If you see there's enough room to run your cam, you can use the cheap Z-28 springs (p/n 98214) w/o the damper like sold by Competition Products, etc. for about $30/set.
Now, the Z-28 springs have 120 pounds on the seat @ 1.7" installed height and 300 pounds @ 1.250", coil bind at 1.160" and is good up to 0.510" lift. These specs are more in keeping w/what you need for your choice of a hydraulic roller cam, rather than the Edelbrock springs brought up earlier- springs that AFAIK are available in a set of 12 only, not 16 as would be needed for a V8 application.
Old 06-11-2011, 05:13 PM
i was gonna go for the springs from http://www.alexsparts.com/products/V...AT-TAPPET.html but those z28 springs you suggest are alot cheaper and found em on summit i think i will go for those instead
Old 06-11-2011, 08:13 PM
techinspector1's Avatar
Wiki Edits: 326
The problem is interference between the bottom of the retainer and the valve seal or top of the valve guide. I don't think just changing springs is gonna do anything to alleviate the clearance problem. You'll also have to change retainers or do a ghetto grind on your stock Vortec retainers. If I were doing this, I'd turn them upside down on the table of a surface grinder, throw on the magnet and cut 'em thinner.
Chevrolet says the stock arrangement is good for only 0.430" valve lift. This allows a safety margin so that the bottom of the retainer will not strike the top of the seal. If you want to run the cam you linked, at 0.465", then you need another 0.035" cut from the bottom of your stock retainers or you need to pony-up for a retainer that is built a little differently and will allow the clearance without machine work.
Personally though, if I were doing this on a grocery-getter type motor, I'd install the Z28 springs and call it good. You'll be moving into your safety margin a little, but with a low-rpm street motor, I wouldn't worry about it. Use a socket upside down on the seals and tap with a small hammer to insure they are seated all the way down on the valve guide. It's been a while, but I think I remember using a 1/2" socket.
Old 06-12-2011, 12:27 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Where do you see that, TI? I've done a little looking around on the subject, and I'm sure I've never seen that small of a figure used. I mean, the exhaust lift on the Vortec is 0.428" or some such. And w/a stock cam, there is a ton of room between the retainer and seal.
On the set of Vortec heads sitting in my shop as I type, there is room for a 0.470" lift. I'm not saying ALL Vortec heads are going to be the same, but I will say that there's no harm in measuring to see just what can and cannot be used.
In any event, it is my humble opinion that NO published figures are any replacement for actually, physically measuring. YMMV.
Old 06-12-2011, 02:40 PM
Wiki Edits: 326
This statement is golden.
Manufacturing tolerances can allow the finished product to be all over the place and it is incumbent upon all of us to check every single measurement on every single component.
For instance, it makes me very sad when you ask a poster what the piston deck height is on his build and he hasn't a clue what you're talking about.
The 0.430" number was pulled from memory after reading data several years ago from one of the GM dealers who specialize in modding the L31 heads. It could have been Gilbert Chevrolet or Sallee Chevrolet or Scoggin-Dickey. At any rate, here's an article from Sallee that shows a limit of 0.420" with 0.030" clearance. Look at the "Vortec cylinder head technical information".
http://www.sallee-chevrolet.com/Cyli...ads/Vortec.cfm
Mark, you and I and most of the regulars on this board would not even think of assembling ANYTHING without knowing every measurement and how it was going to affect the entire package, but there are many enthusiasts out there who will jump in and do what they think is right and proper without having the expertise to move forward. Sometimes I think there should be an Engine Assembly Police who would be put on alert every time someone purchases a car part to question them about what they're doing and to determine they will improve the machine in some manner. Matter of fact, in Orwell's world, it might come to that.
I noted with interest your statement on valve train points in the Wiki concerning max lobe lift with the OEM roller cam arrangement. You other fellows should be aware of this also. On an aftermarket camshaft, if the lift is excessive, then normally the base circle of the camshaft will be reduced, sometimes to the point that the lifter can fall out the bottom of the dogbones and things will get ugly in a hurry.
http://www.crankshaftcoalition.com/w...oints_To_Check
broken valve? valve spring is sitting off center from rocker tip. zoomo Engine 63 03-25-2011 08:37 PM
Cam and Valve Spring help?? 89SDime Engine 3 03-27-2006 10:46 AM
Valve spring ????? 66truck4spd Engine 1 08-25-2005 06:52 AM
Valve spring help Stinky Engine 4 07-01-2003 06:48 PM
valve spring yannick Engine 3 03-09-2003 08:33 AM
