Depends on your set-up, but .005 to .010 on the diameter. Also the fit on the guides should be as close as possible...not tight. If you can't use a locator (I.D.) without wacking the guide boss, use a cup. Some ID locators just don't work, and then you go with a spring cup. That sits in the spring pocket and has no fittage on the guide boss. Check your installed height and don't leave excessive clearance in the coil bind deal! Shim as necessary. Your retainers should be matched to the springs, and if from the same maker should have the proper clearances - you would think. What springs, retainers locators etc are you using? Have your bosses been cut for seals? If so, what's the diameter? What diameter spring seat on your heads? What valve spring? What heads?
I'm using aluminum heads, spring pockets are 1.550" OD., bronze guides OD..560", Dual springs no damper ID.796", The reason I ask is when looking in my CompCams and other catalogs they seem to have clearances as much as .100" between spring & retainer and spring & inside spring locator seats. I'm looking for a measurement that wont be too tight when hot/cold and not so loose that the springs are going to be moving around. The springs I'm using have specs identical to Comp 914's but much cheaper. The retainers I have have closer spring to retainer tolerances than most I see in the catalogs and when I looked up the matching brand retainers for my springs. http://cgi.ebay.com/ebaymotors/PERFO...QQcmdZViewItem This is what I have now> DualSprings- OD=1.437", ID Outer Spring 1.084",ID Inner Spring .790" Titanium retainers OD.=1.347, ID.Outer Spring= 1.072, ID. Inner Spring = .717 Last edited by SSedan64; 06-10-2008 at 04:19 PM. Reason: spelling |
This is going to depend on what you choose. There are plenty of compatible spring/retainer/lock/locator combos out there. With what you're doing it may require you to actually measure and fit everything as opposed to getting what a specific mfr has to offer. If you have movement top or bottom your springs are going to be all over the place. Even with the proper set-up there can be a lot of motion in the springs (Beehive) / (Dual Spring) / (Triple Spring) . If you do not set-up with minimum coil bind clearance (read too much) this may increase the motion of the spring and create problems due to wear and/or breakage.
Stroke I knew things up top flexed but I've never seen an actual SpinTron running in time lapse. That's amazing how much those stems were flexing.
And the rocker bounce too. Good site. They must have a very expensive camera to catch that many frames per second. |
| Correct way to set valves on sbc w/ solid flat tappit camshaft? | Joshua Lee | Engine | 17 | 02-09-2011 05:55 PM |
| master cylinder interchange | runn141 | Suspension - Brakes - Steering | 7 | 05-03-2009 05:15 AM |
| Valve Spring Compressor Tool Question | leejoy | Engine | 10 | 02-27-2008 11:57 AM |
| Comp Cams Valve Spring Questions - Selection | leejoy | Engine | 11 | 11-10-2007 05:42 AM |
| piston to valve clearance. | 85 regal | Engine | 1 | 04-13-2004 08:09 PM |
