valve spring prep update - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-11-2006, 09:47 AM
GoneNova/406's Avatar
a couple of days ago i ask if anyone had ideas i didn't know about for prepping new valve springs and machine shop tom gave me a good idea.at the shop he uses a parts cleaner tumbler and it made me think of a way to tumble them at home.i used an old approx. gal. sized tupperware container and took the dampers out of the springs and put the springs and dampers in the container with phone book cover sized card board and a hand full of new 3/8's nuts.i taped the container shut very well and put it in the dryer with a bunch of rugs and ran them thru a complete cycle.the cardboard cleans and buffers the affects of the steel hitting steel.it takes the sharp edges off the spring coils and damper ends.you still need to run the ends of the springs over fine emery paper and radius the ends of the damper with the grinder of your choice.i used the bench grinder,dremel type grinder and finally a fine file.i've done it using shop tools only but liked this better.its for people who don't have access to all the pro tools.i hope it helps some one.it could be used for other things too.
Old 01-11-2006, 04:57 PM
King of my Man-cave.
I'm glad it worked out for you. Remember you only do this to uncoated valve springs.
My wife gets mad at me when I put silly things in the dryer. Ink pens, washers, loose change, paper clips, wallets, work clothes, things like that really bug her!
tom
Old 01-11-2006, 05:09 PM
johnsongrass1's Avatar
Race it, Don't rice it!
tom
The family cat, My kid sisters boyfriends, Loose papers...
Old 01-11-2006, 08:14 PM
NAIRB's Avatar
When your wife finds out what you are doing, you will be buying a new dryer.
Old 01-11-2006, 08:25 PM
Don't tell her you used the dishwasher for a parts cleaner, either.
Old 01-12-2006, 05:35 AM
Why not try copper exhaust nuts or put the springs in the case tumbler with a bag of wallnut shell media and 100 375 H&H mag once fired cases?
Fabricating intake manifold. gemini86 Engine 25 10-02-2009 02:10 PM
Valve spring ????? 66truck4spd Engine 1 08-25-2005 07:52 AM
Dart Pro 1 Valve Spring Pockets 68NovaSS Engine 4 02-18-2005 08:41 PM
broken valve spring dampner nastynova Engine 18 07-04-2003 10:28 PM
Valve spring help Stinky Engine 4 07-01-2003 07:48 PM
