Originally Posted by leejoy
thanks Tom -
More feedback please ...............
If you plan on that little of use, probably wouldn't hurt to remove all rocker arm tension on them when you expect it sit for long periods of time. It will help the springs tension last longer and also keep all the valves closed so a draft isn't created and moisture from entering some of your cylinders and causing problems there if it is humid and not in a good climate controlled environment....info that tom gave is accurate on open and closed rates!
