Valve Spring Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-19-2008, 09:05 AM
540z's Avatar
Brute force and ignorance.....
Hey Guys,
I'm replacing the valve springs in a 327 and I am wondering if it is really necessary. I have changed the cam from a 7102 Edelbrock to a 255H Comp. The existing springs (Edelbrock P/N 5703) are listed as having a seat pressure of 104-116 lbs, and the new springs (Comp P/N 981-16) are listed as having a seat pressure of 105 lbs.
The existing springs have very low run time on them and I was wondering: do they really need to be swapped out? How critical is the possible 11 lbs difference in seat pressure?
Thanks,
TR
Old 06-19-2008, 09:09 AM
Double_v23's Avatar
Horsepower Enthusiast
Last journal entry: Finished BMOD001FH
What is the compressed pressure at the lift your cam has? If they are pretty close then I would say just leave em in there.
Old 06-19-2008, 09:32 AM
540z's Avatar
The #5703 Edelbrock springs open pressure is 330 lbs @ 1.180 and the #981 Comp springs open pressure is 273 lbs @ 1.250. 57 lbs sounds like a big difference. In reality, is that enough to cook the face of a new cam or squash a lifter?
Old 06-19-2008, 09:50 AM
SSedan64's Avatar
According to my Comp catalog the Comp 981 measure 316# @1.200", if compressed .020" more they would be the same as the Edelbrocks, should work fine.
700R4 – Why are the TCI manual valve body instructions so lousy? Bayley Transmission - Rearend 24 02-16-2009 12:49 PM
cam question, any truth to this? 406 ss monte Engine 9 03-30-2008 11:28 AM
Comp Cams Valve Spring Questions - Selection leejoy Engine 11 11-10-2007 05:42 AM
Broken valve spring??? Miligav383 Engine 6 05-16-2004 09:40 PM
