Valve Spring question - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-20-2013, 07:25 PM
fastnloud's Avatar
I'm using a hydraulic flat tappet cam with .515 lift
I was wanting to get these valve springs, they are suppose to be good to .550 lift.
http://www.summitracing.com/parts/sum-174000
Is that enough of a safety margin with the springs?
Thanks guys.
Old 04-20-2013, 07:39 PM
BOBCRMAN@aol.com's Avatar
Should be good for your application. Keep closed seat pressure around 110 lbs.
The Following User Says Thank You to BOBCRMAN@aol.com For This Useful Post:
fastnloud (04-20-2013)
Old 04-20-2013, 07:41 PM
fastnloud's Avatar
Alright, thanks.
I read about having a .060 safety margin, so does that mean with a .515 lift cam, I need springs that are good to .575 lift? I may be doing the math wrong.
Old 04-20-2013, 07:54 PM
Those springs have a safety margin already figured in.
The Following 2 Users Say Thank You to BOBCRMAN@aol.com For This Useful Post:
fastnloud (04-20-2013), techinspector1 (04-21-2013)
Old 04-20-2013, 07:55 PM
fastnloud's Avatar
Alright, thanks. I didn't know that.
Valve Spring question jr2009 Engine 9 05-26-2009 07:35 PM
valve spring question bracketracer Engine 5 04-05-2009 07:00 PM
Valve Spring Question 540z Engine 3 06-19-2008 09:50 AM
valve spring question Casperdude898 Engine 2 04-07-2008 01:38 AM
valve spring question dboyett38666 Engine 9 03-19-2006 05:15 PM
