Valve spring retaining rings needed? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-18-2009, 08:27 PM
My fuelies, as do most stock heads, had rings around the top of the valve springs. I replaced the springs with a set of z28 springs that came with springs, retainers, and locks but no rings. Are these needed or not? I did not think they were needed but then got the heads together and it looks like the springs move around without the rings.
I have seen many heads without these rings but most stock ones have them. Are they needed or not?
Old 03-18-2009, 08:37 PM
SSedan64's Avatar
Those are oil shields, they help keep oil off the stem. Not neccessary. If you want to use them be sure to recheck your installed closed spring pressure because they're about .030" thick. May not make enough difference to have to make an adjustment.
Comp Cams Valve Spring Questions - Selection leejoy Engine 11 11-10-2007 05:42 AM
Valve Spring Compressor Tool Help leejoy Engine 11 11-01-2007 11:24 PM
setting valve spring on installed height question 406 ss monte Engine 4 09-01-2007 04:01 PM
Help! Valve spring seat pressure? camaro 68 Engine 3 05-20-2005 11:43 AM
valvetrain gurus: need help identifying mysterious valve noise blndweasel Engine 10 03-04-2003 07:59 PM
