-   Garage - Tools (http://www.hotrodders.com/forum/garage-tools/)
-   -   Valve spring seat cutter (http://www.hotrodders.com/forum/valve-spring-seat-cutter-226602.html)
MouseFink 11-28-2012 11:28 AM
I need a valve spring seat (pocket) cutter that will cut a 1.325" OD seat. The smallest I can find is one that cuts a 1.350" OD pocket. My valve springs are 1.310" OD and I would like about .007" - .010" clearance to limit spring movement (dancing) at high RPM. There are no spring cups that fit. Maybe some motorcycle valve spring seat cutters?
I heard a rumor that someone offers an adjustable seat cutter.
BOBCRMAN@aol.com 11-28-2012 03:54 PM
GOODSON : Engine Building Tools and Supplies VSS 1320 is closest with 1.320 od.
MouseFink 11-28-2012 03:59 PM
Thanks, the Goodson VSS 1320 will work perfect for my 1.310" OD valve springs
