valve springs
the heads i bought from a friend have triple valve springs and the lift capability is .600, the cam im pruchasing is int/exh 300/300 and lift is .518/.530, will the springs work or do i need some different ones?
thanks |
I hope you are running good studs with guide plates also. JMO
Cole |
yes they do have very good stud girdles!
the cam I'm putting in is a solid flat tappet camshaft |
"Triple springs" might be a true triple setup which would be for a roller cam and have way too much pressure for a flat tappet cam or it could be double springs with a dampner which might be ok.
As Bob mentioned I would measure the spring pressure to be sure. Most solid lifter cams in the range you're using require somewhere in the neighborhood of 130# of pressure on the seat. Trying to use roller springs would eat that cam in a hurry.
BSE Racing Engines |
never heard of him, but ill definetley look him up, thanks
| master cylinder interchange | runn141 | Suspension - Brakes - Steering | 7 | 05-03-2009 05:15 AM |
| valve springs, valves, push rods, and rocker arms | elcaminodragster | Engine | 7 | 01-28-2008 08:48 AM |
| Valve springs @seals | JMEDLEY001 | Engine | 1 | 12-12-2006 09:25 PM |
| Can I exceed the lift that is recommended for my valve springs? | surfshark | Engine | 7 | 11-18-2006 12:13 PM |
| BBC Valve Springs Diameter | JamesRS | Engine | 4 | 02-09-2006 08:22 PM |
